Upcoming project
In a few weeks im probably going to start doing my clutch. My question is what should i expect to change besides the clutch, PP, TO bearing? Is there anything else to order since im trying to stock up all the parts before the project. At the same time im also getting a lightened flywheel, slave and master cylinders, and trans mount which is one of the main reasons im doing this. I figured since the trans has to be lowered i may as well fix my clutch i know is bad. The clutch im going to buy is the lr spec stage 2 and im getting the solid trans mount for durability. My question with that is what are if any downfalls to the solid mount? I know noise is one but just how bad is the noise? Is this recommended? Thanks
Old 09-28-2005, 05:23 PM
meister member
speedracing944's Avatar
Repack the C/V joints, drain and refill the transaxle with fresh fluid and make sure every part you pull out is cleaned before reinstall. What kind of shape are your torque tube bearings in? If they are noisy, now is a good time to change them.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-28-2005, 06:44 PM
Im not sure if my torque tube bearings are good or not, i get a fast tapping noise i guess on deceleration in lower gears. I was kinda contributing that to the clutch center but who knows. are the bearings cheap to replace anyway?
Old 09-28-2005, 08:02 PM
when you pull the flywheel replace the rear seal
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 09-29-2005, 03:20 AM
Parrothead member
VINMAN's Avatar
With the trans out, check all the seals on the trans.
Vinny
Old 09-29-2005, 07:19 AM
also, is it normal for the cluch to be stiff when the car isnt running then soften up a little bit when running?
Old 09-30-2005, 04:26 PM
