-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   What can i tune up on my 944? (http://forums.pelicanparts.com/showthread.php?t=244243)
pearljaman31 10-03-2005 06:42 PM
I think my car needs a major tuneup. Im currently getting 17mpg, using premium gas and driving it softly. Maybe 4 months ago i replaced the air, oil and fuel filters. Recently i put in new spark plugs and transaxle fluid. What else can i do to fix my sick car? Its an 83' with about 70k miles.
I purchased it in fef of 05' and it had been sitting for awhile. But ive been using it as a daily driver since i bought it, and have put about 5k miles on it.
Techno Duck 10-03-2005 07:16 PM
Ignition Wires
Distributor Cap
Ignition Rotor
Fuel Pressure Regulator (only if your car is running rich)
O2 Sensor
Vacuum lines
CJFusco 10-03-2005 07:35 PM
Okay. First of all "Premium" is just a marketing ploy by the gas companies. The octane of gas has nothing to do with quality. The octane refers to knock rate -- the only reason you should run 93 octane gas if your car doesn't call for it (I believe 87 octane is fine for a stock 944) is if you are getting knocking/pinging from the engine at high revs. Otherwise you are just throwing money away.
The standard tune-up is cap, rotor, plugs, oil, and filters. Ignition wires might be needed if yours are old and worn.
Test the 02 sensor; unplug it and see if the car runs better with it unplugged. Is the car running rich (gas smell even at idle)?
