question about 8 valve heads
Can an earlier 8valve head fit on an 86 or were there changes made. I am looking for a bolt on head for my 86 on Ebay and would appreciate any help.
winter-hater club member
i think there were changes, especially for the turbo. i'd try to get a matching year, just to be certain. also, try 944ecology.com. they offered me a good deal on a complete head. put an add on the used parts forum. i ended up buying one from another pelican member for a great price, worked beautifully.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Thanks nynor, best case senorio is I would find an exact year match but have limited budget. I have a n/a 86 auto. I've seen a couple of bolt ons on Ebay for under $200 but dont want to get the wrong size.
They bolt right in.....
All the 2.5 NA and Turbo heads will bolt on to your car....
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
its not so much a matter of size, but they changed some of the water/oil channels year to year.
if you have your head off, see if you can find an exact match on ebay.
are you sure? it seems that i've read a lot of debate on this subject.
There really shouldn't be any debate on this one?
They all use the same headgasket. Note: Only 2.5 NA and turbos.... 16v,2.7 etc dont obvoiusly apply... I have an 89 Turbo, 86 Turbo head on my counter..... and they both fit the 86 NA... no issues. I had an extra 83 for a while as well. All relatively the same..... Well the turbo ones are different.... but they will bolt on.
learn something new every day.
thank you everyone for your input. I see that they will all bolt on including the turbo excluding the 87 on with 16 valve. The question is are all the N/A heads the same in cam duration? I know the turbo will have less compression but did any head change from 1st year 944 to 16 valve? since 150Hp did not change I assume that heads did not change?????? Any one???
Ornery Bastard
http://www.cantonia.com/specifications.html Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Dog-faced pony soldier
Heads are the same - turbo ones have ceramic-lined exhaust ports and sodium-filled exhaust valves. Other than that I think the differences are minimal, if any.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
