Q how to keep headlights popped up?
With Winter coming I think I may want to keep the lights popped open with the car off in icy/showy weather to avoid them icing over and causing a problem opening. Is there an easy way to do this?
Thanks Graham |
You can open them and pull the headlight motor fuse. The owner's manual or Haynes manual would tell you which fuse, I'm not sure which.
I kept them down while using the car last winter, if you just hit the ice/snow with the ice scraper (like strike, not scrape), it breaks it up enough to open. The system is surprisingly good, it doesnt get stuck or broken too much. |
you're lucky! i can't get the dang things to go down when it's below 50.
keep the dream alive! 1988 944 NA (purple) |
put them up... turn the car off... then turn off the switch completely.... the parking / marker lights will go out, and your lights will stay up.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
That Guy
You have two options, either roll them up manually via the headlight motor, you need to pull off the rubber boot on top. Either that or as yellowline suggested which is much easier, turn the headlights on and pull the fuse for the headlight motor.
Think of the aerodynamic drag and decreased fuel efficeny you will get! Are you sure you want to do that!? ![]() But i have had pretty good luck with them never freezing over however in the two winters i have expierenced.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 11-23-2005 at 04:09 AM.. |
why not do what i suggested? u dont have to muck around with fuses, and if u do actually want to put them down it's just the flick of a switch...
Non Compos Mentis
On my car, if I turn the car off, then the lights off, the headlights go down..... That's probably why nobody supported it.
Best bet is to put them up and pull the fuse. However, even up here in Calgary, I've never had a problem with them icing shut.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Ornery Bastard
I've had a few cars with retracting headlights and I've never once had them get stuck down.
I did have them get stuck up once on my old Accord, but that was because I was driving home practically through a blizzard and snow had filled the bucket that the lights retracted into. The mechanism actually hadn't bound up, there was just no room for the lights to go down!
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
winter-hater club member
i've had mine freeze closed. popped the fuse when i turned the headlights on.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Dog-faced pony soldier
Viagra?
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Every time the weather looks bad, I pop them up and pull the relay off the headlight motor.
Black 944 NA |
Ornery Bastard
Thanks for the reply's everyone. I think I will just wing it based on what most of you have recommended and just leave them alone. If I have a chance I will scope out the relay/fuse this weekend.
Thanks Graham
Early 85 944 Factory Cold Air Intake Radial Tires |
