-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Q how to keep headlights popped up? (http://forums.pelicanparts.com/showthread.php?t=252705)
GMingst 11-22-2005 09:17 PM
With Winter coming I think I may want to keep the lights popped open with the car off in icy/showy weather to avoid them icing over and causing a problem opening. Is there an easy way to do this?
Graham
yellowline 11-22-2005 09:28 PM
You can open them and pull the headlight motor fuse. The owner's manual or Haynes manual would tell you which fuse, I'm not sure which.
I kept them down while using the car last winter, if you just hit the ice/snow with the ice scraper (like strike, not scrape), it breaks it up enough to open. The system is surprisingly good, it doesnt get stuck or broken too much.
BananaClip 11-22-2005 11:05 PM
you're lucky! i can't get the dang things to go down when it's below 50.
Eldorado 11-23-2005 12:59 AM
put them up... turn the car off... then turn off the switch completely.... the parking / marker lights will go out, and your lights will stay up.
Techno Duck 11-23-2005 04:05 AM
You have two options, either roll them up manually via the headlight motor, you need to pull off the rubber boot on top. Either that or as yellowline suggested which is much easier, turn the headlights on and pull the fuse for the headlight motor.
Think of the aerodynamic drag and decreased fuel efficeny you will get! Are you sure you want to do that!?
:D
But i have had pretty good luck with them never freezing over however in the two winters i have expierenced.
Eldorado 11-23-2005 07:40 AM
why not do what i suggested? u dont have to muck around with fuses, and if u do actually want to put them down it's just the flick of a switch...
Dantilla 11-23-2005 07:54 AM
Huh? As soon as I turn the key off, the headlights close.
Zero10 11-23-2005 09:15 AM
On my car, if I turn the car off, then the lights off, the headlights go down..... That's probably why nobody supported it.
Best bet is to put them up and pull the fuse. However, even up here in Calgary, I've never had a problem with them icing shut.
AaronM 11-23-2005 01:00 PM
I've had a few cars with retracting headlights and I've never once had them get stuck down.
I did have them get stuck up once on my old Accord, but that was because I was driving home practically through a blizzard and snow had filled the bucket that the lights retracted into. The mechanism actually hadn't bound up, there was just no room for the lights to go down!
nynor 11-23-2005 03:19 PM
i've had mine freeze closed. popped the fuse when i turned the headlights on.
Porsche-O-Phile 11-23-2005 05:28 PM
Viagra?
jim302 11-23-2005 05:56 PM
Every time the weather looks bad, I pop them up and pull the relay off the headlight motor.
AaronM 11-23-2005 07:00 PM
There should be a clutch or some mechanism to prevent that... There was on the old Accord and I took it for granted that there was one on the 944.
GMingst 11-23-2005 07:04 PM
Thanks for the reply's everyone. I think I will just wing it based on what most of you have recommended and just leave them alone. If I have a chance I will scope out the relay/fuse this weekend.
Graham
