Burn the fire.
Brando's Avatar
Talking SoCal Clutch Help - Finishing the Install
Hello again guys. I've yet to finish my clutch job because of lots of changes at work. I really need to get the car done within the next 2-3 days as i am now on vacation until the 9th (next friday).
The car is still in Costa Mesa, NOT Riverside. I have the new clutch/pressure plate and associated bearings installed and the torque tube bolted up to the bellhousing. Currently the transmission is out of the car and I have to re-install the TDC Sensor, Speed and Reference sensors. I do not know how to properly set the sensor and I do not have any special tools to do so. I should be at my friend's house by 8AM to get started on the car. If you can lend a hand please send me a PM and I will give you contact info and directions or an address. Thanks in advance to those who can help, and have helped (Craig, you da man!).
~B
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 12-02-2005, 05:53 PM
pokey's Avatar
Send a message via AIM to pokey
I can probably help during the week. Give me a call on Monday.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 12-02-2005, 06:19 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
on my second clutch job on a friends car i found that the sensors had to be removed but the braket diddnt so no adjustment was necessary. On my car i followed the procedure about gluing a washer on the sensor and setting it that way. .8 mm i believe. It wasnt too hard actualy. good luck!
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 12-02-2005, 09:35 PM
Burn the fire.
Brando's Avatar
i can always take the glue and washer off, right?
So far all is going OK... goimg to install the trans next.
Old 12-03-2005, 09:22 AM
Will work for parts
944 boy's Avatar
Sorry, if forgot to mention that part. I used a silicone window sealent that stck well enough but came off in one gooey piece. You do have to remove the washer.
Old 12-03-2005, 04:09 PM
May the Porsche gods be with you.
86 951 2.8L Andial Engine Garnet Red
Old 12-03-2005, 08:31 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Just saw this - hey didn't realize you were relatively close by. You still need help on this? I can swing by in the evening some night this week or whatever if needed. . .
Black Cars Matter
Old 12-04-2005, 10:14 PM
pokey's Avatar
So, how's it coming?
1956 Ford F250
1955 BMW R69
Old 12-05-2005, 12:10 AM
Burn the fire.
Brando's Avatar
IT'S FINISHED!!!
Monday night I left off with a bad battery and the car would not crank over fast enough to start the car. Called Hugh (SoCal Driver) Tuesday morning and he was gracious enough to help me clean the contacts and get a new battery. Swap the BG/DG sensors into the right spots and cranked her over! Started right up and idles smoothly. No more wierd vibrations through the whole driveline and a fresh spring-center clutch that's working fabulously. If not for work I would have had this car done in a week and a half. Re-installing everything was easier than taking it apart and cleaning it all.
I want to give a special thanks to my friend Scott Kline, Hugh (SoCal Driver) and Craig (McFly944) for lending their help. I surely would have been on a flatbed to my friend's shop right now if not for them.
Old 12-07-2005, 11:14 AM
pokey's Avatar
Very cool! We should have a going away get together. When do you leave?
1956 Ford F250
1955 BMW R69
Old 12-07-2005, 12:19 PM
Cali56's Avatar
my sensor's had some grease pen marking on the plug but not on the mount, not sure if I got them plugged into the same bolt hole, is there a way to determine which one goes where without starting?
"don't quit"
Old 12-07-2005, 03:22 PM
Burn the fire.
Brando's Avatar
Details can be found here:
914Club Going Away Party.
All the 944ers are welcome to attend as well
Old 12-07-2005, 04:40 PM
McFly944's Avatar
Im glad to hear you got it going again. I had never heard from you to know if you needed the extra hands, anyhow good job.
Hooters, one of my favorites! You can count me in for sure.
Craig -
86' 944 N/A Black <-----Daily driver under going a fresh motor install to resume daily driver duties
Past:
89' 944 S2 Guards Red Now in the hands of a Pelican who has been wanting another p-car
Old 12-07-2005, 08:00 PM
