My Cigarette Lighter in the 87 924S quit working and cannot figure out why
all fuses seem o.k. and everything else works so does that mean the actual lighter assy needs replacing?? It has never been used for cigarettes and looks brand new inside and yes it has worked before I used it last winter for a heated seat cover and wanted to use it this winter again. Also just remembered that if I ever have a flat that I need it to pump the spare tire up!! Any help is appreciated. Thanks, Marcel
1997 Porsche Boxster Red 1993 Porsche 968 Red 1988 Porsche 944 Metallic Gray 1987 Porsche 924S Red 1987 Porsche 924S White |
Your car is telling you something -- get a chest x-ray.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
I'd guess the wire came lose off of the unit, being that it wasn't used for cigs.
Still looking for the right deal on another P-car 1968 BMW 1600 2 liter 1956 Ford F250 1955 BMW R69 1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...) |
OK. I'll get the x-ray.
SoCal, please do. We don't want to lose another one of the '44 gurus. Also, come out to the next gathering o' '44s, have a couple beers, and put faces with screen names/avatars.
Marcel, You'll need to pull the socket to test if it's the wire, or the socket itself, or some where else in the wiring. But, I'd start at the socket end with a test light.
Was thinking of a head x-ray and not a chest as I have never smoked. But I did grow up in a smoking household.
Ahhhh...
Easy for you to say!
Actually, that was me trying to breathe after growing up with a father who smoked four packs a day, and a mother smoking two. I feel your shortness of breath...
Mother made it to 62. Then got the hole in the neck when they took all of her vocal cords and stuff out. We swear she still would smoke for the next year and a half it took her to die.
I have back ground asthma. Comes on with heavy colds and such. A real pain. Back on subject: What was being plugged into the socket? I know that one of the cell phone chargers I have just will not stay in. The other does. Could have fried the socket.
I plugged a set heater into socket last winter and it worked fine.
This year I tried again but does not work. How do you tell if socket is fried? I would think that fuse would blow before it would fry a socket? By the way the socket looks o.k. by looking at it, clean and shiny. Marcel
After the Xray and normal smacking:
Check Fuse #7: Also controls Radio, Clock, and Inside lights: After that, check that you are getting voltage to the socket. I think there are two slip on spade type connector behind the console that also might of come off. Bad connectors usually have brown marks on the nice clean shine where Mrs. Electricity was up to mischief. |
So does anyone know how to remove the lighter assy to inspect the wires?
Does the whole center console panel need to be removed? Thanks, Marcel
is it possible that your seat warmers are broken and not your lighter socket?
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
No the lighter does not work either!
Marcel
