Send a message via AIM to projekt70chevel
Please help my 944 live again
Ok I have had endless problems with my porsches ignition system it seems. I first had a problem when the car died just before my first AutoX event
Ok so I thought I solved all my problems. But she died on me agian except this time she wont refire. I have a new igntion switch and relay. I even hooked up a jumper just to check the relay but no ignition. Not only does the car not start but the power windows wont work so I'm stuck with my windows down in winter... So any help would be aprpeciated, whats the best way of tracking my problem down.
Patrick
Old 12-22-2005, 05:20 PM
Check yer fuses and relays amigo
here's a diagram
http://www.network54.com/Forum/426130/message/1134482918/1984%20944%20Fuse%20and%20Relay%20diagram,%20and%2 0identification%20chart
and clarks garage too for some diagnosis under garage shop manuals
Its under the letter E starting and runnign problems
http://www.clarks-garage.com/
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 12-22-2005, 10:38 PM
Just thinking out loud
mattdavis11's Avatar
Check the terminals, and ALL wires at the + side of the battery. Sounds as if a few no longer make a good connection.
Patrick, what year? Throw it in your sig.
91 FJ80
84 Ram Charger (now gone)
Old 12-22-2005, 11:00 PM
I second that.. and Make sure ground post is clean.. use a wire brush clean both terminals use a lil brake parts cleaner to clean it up.. and use some hight temp grease.. so far has worked for me
Jaime O.
Old 12-22-2005, 11:18 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
The fact your windows don't work tells me the problem is the power is not getting to any part of the vehicle not just the ignition. Trace the positive and negative leads of the battery to make sure all ends have solid clean connections and/or replace the battery cables. You can use a voltmeter to check the amount of volts you have at each connection. Does the starter turn over okay?
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 12-22-2005, 11:39 PM
Starter turns over fine, relays and fuses are good, only thing that doesnt work the car not starting and the windows... everything else is fine. I have had problems with the terminals not making a good connection. But I just cleaned them up and no change. I should add that the car died while driving if this helps... Now I guess its time to invest in a voltmeter and use clarks stie and track this stuff down
O and its a '84
You need parts let me know
Parting out under the hood and interior
Old 12-23-2005, 08:17 AM
ae1969's Avatar
Send a message via ICQ to ae1969
In your early 944....... as I recall you have the same switches as I had in my 924. LOUSY.
THere are tiny little ballbearings that are part of the contact. You can pull the switch and make sure you have power.....but I have a feeling its just the switch.
No start - check if you have spark and fuel. Let us know what you find.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-23-2005, 08:50 AM
Well I was using the voltmeter I found that I had almost 3 ohms when I had the key in the starting position... So luckily I have a spare switch and what do ya know we have IGNITION.
Patrick
Old 12-23-2005, 09:59 AM
