Hose size to fit on fuel rail?
According to the Haynes manual, to check to see if there is fuel to the injectors, you unscrew the end of the fuel rail and hook a hose up to it to drain into a container. What size hose is it??
Tact57 late 85 944 95 BMW 325 is |
Just unscrew the cap a little. If there is pressure you'll know it.
What problems are you having?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Engine is rolling over by will not start. I change the fuel relay. Still won't start. So now step two: Is fuel being sent to injectors.
Have any suggestions? I was even thinking the coil. How do you test the coil?
