winter-hater club member
nynor's Avatar
how do i turbocharge my 951?
Originally posted by Z-man
Can someone start a post on how to turbocharge their 944 n/a or something??
Thank you,
-Z-man.
just kidding!!!
ajajajajajaja!
"COOL PRIUS!" - Nobody Ever
Old 12-19-2005, 08:58 AM
Z-man's Avatar
If I may quote what Tifo has stated in the past -
Here are the steps to upgrade a 944 n/a to a 951:
1. Open hood of your 944 n/a.
2. Locate the coolant overflow tank. It's that yellowish plastic tank just behind the driver's side headlamp unit.
3. Carefully remove the overflow tank cap. Note: do not do this while the engine is still hot. Wait for the motor to cool down.
4. Take overflow tank cap and find a 951.
5. Place cap on coolant overflow tank of the 951.
6. Drive off in your upgraded car.
Congratulations! You have upgraded your 944 n/a to a 944 turbo!
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 12-19-2005, 09:21 AM
nynor's Avatar
LOL!!
Old 12-19-2005, 09:23 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Wouldn't work - the n/a reservoir cap is inferior to the turbo one and will never stand up to the extra power.
Black Cars Matter
Old 12-19-2005, 09:48 AM
Z-man's Avatar
Not necessarily - if you've got an M030 spec cab from your 944 n/a, is should work just fine on the 951, unless, of course, the 951 has the upgraded 951-M030 spec cap. Then, indeed, you're 944 cap may not be able to withstand the increase in pressure. But a 968 M030 3-way adjustable rear sway bar (set to the middle setting) should be able to compensate for the inferior cap. Unless, of course, you have a limited slip differential.
But I digress...
-Z-man.
Carpe Viam.
Old 12-19-2005, 11:14 AM
So much pressure..so little gain.....
Bob S. former owner of a 1984 silver 944
Old 12-19-2005, 11:16 AM
Eldorado's Avatar
and if all else fails...... this should work....
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 12-19-2005, 03:30 PM
One apex at a time
Dean924s's Avatar
Just add one of these.
http://www.marx7.org/%7EDSMITH/vortech.htm
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 12-19-2005, 08:08 PM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
It does! I saw an early in a junkyard once with one of these right after the 944 badge.
keep the dream alive!
1988 944 NA (purple)
Old 12-19-2005, 08:16 PM
Registered Lunatic
Ya, know.
I won't bet much, maybe a buck or so. . . but I'd be willing to bet, with money not being the object, I could get 200hp out of a NA 2.5L. . . no added turbo, no supercharger.
Let's see:
Up compression, around 10:1 or 10.5:1
More duration and lift
cat test pipe
headers
big bore throttle body
Port/Polish (again, for what polishing worth on an engine that isn't torn down and cleaned every 500 miles)
Delete the balance shafts
Hotter ignition
Custom chip designed for mods
Recalibrated MAF (this can be taken into account in chip programming though)
Better intake (K&N or the like)
But the real question is . . . . .WHY!!!!!!
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up!
Old 12-19-2005, 09:20 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Hmm.
I took the resevoir cap off my n/a to put on my 951 because the 951 one wasn't holding pressure.
So does that mean my 951 is not longer turbocharged?
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 12-19-2005, 09:55 PM
Eldorado's Avatar
no, it means that it's a TURBO turbo charged... dude! you're pushing the envelope!
Kyle
Old 12-19-2005, 10:02 PM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
Originally posted by ilikemy944
Hmm.
Have you not been listening? That makes it a turbo'd N/A
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 12-20-2005, 08:17 AM
..P ..P is offline
Regards, P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 12-20-2005, 08:54 AM
ilikemy944's Avatar
Hmm, the KLR box is not in that picture
Brad Tompkins
Old 12-20-2005, 05:49 PM
seaboltman's Avatar
I would say that to turbo a 951, you have to add blinker fluid. Its the best and easiest way to turbo your 951
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 12-20-2005, 06:52 PM
Eldorado's Avatar
how about ajajajajajajaja fluid?
Kyle
Old 12-20-2005, 06:53 PM
PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
you need ajajajaja fluid to make ANY car even run
you amateurs know nothing!
combine ajajajaja fluid with "NOS" decals and you will be seeing some serious numbers.
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 12-20-2005, 08:34 PM
Registered Lunatic
I thought you only used that for a better stroke!
Old 12-20-2005, 10:03 PM
Registered Lunatic
I know you've already seen it, but I just had to pull it back up.
http://www.angelfire.com/nc2/mycoffeecan/page1.html
Old 12-20-2005, 10:08 PM
