? on 87 944 automatic transmission
Hi All,
I've got a chance to pick up a nice 87 944 that has AT problems for short $. Car needs to be towed according to owner. Question: how difficult is it to swap in a good trans? How difficult is it to convert to a 5-speed. I work on the 911's with no job too big, just trying to gauge if this is a 1 day, $500 job or a 3 day $1500 job. Thanks for your help. Shaun
Tru6 Restoration & Design |
Never did it myself, but have read up on the subject in case that eventful day ever comes.
From what I gather, a tranny swap (auto to auto) should be closer to the $500 mark (good tranny from ebay or dismantler, doing work yourself). Conversion to 5-speed, I couldnt' say, tho it definitely has been done. Besides the slush box itself, there are a bunch of automatic specific parts that *may* need to be swapped (radiator, for instance, comes to mind (unless you can just plug the auto trans cooling line hoses). What kind of AT problems does the car have? I suppose a damper plate could be considered a tranny problem. Thats a $700+ part and 20+ hrs work for which there isnt any quick fix.
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
Thanks for the reply. Owner says torque converter is bad. Car moves, but barely and only under high rev.
I think livewirevoodoo nailed it pretty well. If you just swap auto to auto, then it's really not that bad of a job. If you switch to 5 speed, you might get by with radiator, but I know the speedometers are different, so you would have to change that among other things within the driveline and interior to accomodate putting a clutch in. If you are wanting a five speed, it's definitely easier to start with that.
Good Luck
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
aw geez, go back to OT where ya belong. There's no reason for you to buy a 944, you'll hate it.
![]() seriously, i'm entirely kidding. auto to manual swap isn't that difficult... there are several threads about it. I picked up a good used 5-speed (from another pelican) for $350, I think. It's been awhile.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
Thanks everyone for your help, I'll post what I find.
if you decide to go with another auto trans, i've got a parts car with one that i'll sell ya.
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
Conversion to 5-speed is tempting! Shaun
Virginia Rocks!
Short list of parts needed when I considered this a year ago. I just bought a "roughed up" 5 speed 3 weeks ago and got it legal yesterday.
http://forums.pelicanparts.com/showthread.php?threadid=187520&highlight=automatic Unless you get it for dirt cheap and get a manual car to sit side by side while stripping parts, I don't think it would be a worthwhile investment in time. It all depends on your perspective however.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Cars & Coffee Killer
Jeez Shaun. You can't leave us to our own little sanctuary? (JK
)Besides having to change the speedo and install all of the clutch plumbing, another consideration is that the stub axles between an automatic and manual are different. IIRC, the driver's side stub axle is shorter than the passenger side on an automatic, but the axles are the same length on a manual. Do you have to pull the torque tube to get to all of the shifter linkages or can that be done from the top? Next Shaun will be asking us how to turbocharge his new toy ...
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Virginia Rocks!
ajajajjjajajajjajaja!!!
He could turn it into the "g9 mobile." Paint it white, stick the G9 logo on it, but way oversized, so it takes up all of the side of the car, up onto the hood... Maybe some flowers along the bumpers, and it could pull streamers from the antenna
![]() Then if you enter it into some parades, I think there's opportunity to make it a tax write-off... or at least some of it. My previous boss did this (minus the girly-ification) with an old pickup.
going to look at the car now.
OK, here's the official scoop on the car:
The bad: Car rolls but only starting at 4K RPM Passenger door bad dent, could be pulled. 4 shades of guards red, needs total paint front tires bald, needs alignment dash cracked both outside door handles sticky seats lightly split, otherwise interior decent 928 dish wheels curbed The really bad: fluid leaking steadily from transmission Is this anything but a parts car? I offered him $300. He wants $500. Thoughts?
For most people, it is a parts car. Your offer is spot on.
However, if the money isn't so important and you are looking for an interesting new project to test your skills, this would be the car. If you could find an otherwise mechanically sound 944 that has frame damage from a major accident (would cost about as much), you could use that car's internals in this car's frame.
Virginia Rocks!
Sounds like a real cream puff. The nice part about that car...if your f* up repairing it, you can't break the broken!
I'm lining up to get started on my conversion now, on an '87 924S auto (which was immaculate and bought cheap). Doesn't sound like there's anything great about the one you're looking at, except for parting. Are manual 944's that hard to find in your area?
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
You are correct. I used the wrong term.
I surf Craig's List for generally unwanted things and this came up. I thought it would be nice to drive in the winter. the 911s are in storage and while the Jeep is great when it snows, I go to NY way too much in it. A 944 would be perfect. If this one had just few less flaws, I'd really consider it at $500.
here's something I really wish I had the spare cash for, if only to put a proper Turbo front end on. Caution, blindness may ensue. http://boston.craigslist.org/car/120921418.html
Tires, dash, paint, tranny (either AT swap or 5spd conversion). Those sound like the big bullets.
Not including purchase price, I'd venture a guess at about $2500 worth of parts and paint, and that is keeping it an automatic. And that is before you get a chance to get it on the road and get a feel for how solid the engine is. Did you give it a once over or do a top to bottom inspection w/ engine compression #s, etc.. For $300 it sounds like a decent parts car, but a b*tch of a project. The $ you spend to get it on the road might be better off spent upfront on something driveable. Just my 2cents.
