Expansion tank hose?
Can anyone tell me where this hose goes to which is connected to the side of the expansion tank on my s2.It appears to go straight down and then pass through the wall in the engine bay right by the expansion tank breather hose.I'm trying to trace a slight coolant leak that i have and i'm wandering if this hose is the culprit.
1989 guardsred 944s2 cabriolet, 1983 metallic claret 924 lux (sold) |
Well on my 83 that tube goes to the Top of the radiator right above the fan switch where the upper radiotor hose also connects
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
Same on the S2.
'95 993 Monster in the making '89 S2/Turbo aluminum grill monster: terrorizing another state |
The plastic nipple on the radiator that this hose connects to has been known to crack. Also the tank where the nipple and the fan switch screw in has been known to crack. A real pain to identify with out removing the radiator.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
what problems could be caused from this not being connected?
1984 Porsche 944 - down for the count, may be rebuilt 1999 Civic ex coupe - Turbocharged fun/Daily Driver |
Same as disconnecting the top hose on the radiator.
