-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   One last belt question before I dig in.. (http://forums.pelicanparts.com/showthread.php?t=259626)
VaSteve 01-06-2006 05:44 PM
I'm going to do the belts tommorow. I am reading the factor manual tonight and it talks about turning the engine "anitclockwise" 1.5 teeth. My question is, "why?"
To relieve any pent up tension?
Sorry for not doing a thorough search.
mike944 01-06-2006 06:23 PM
well, actually, yes.
When you rotate the engine clockwise with a breaker bar, as the timing belt turns the cam, you'll notice that the lower sprocket is "pulling" on the long side of the cam belt. Well, the long side is the side you measure tension on. If that side of the belt has been pulled tight, by the action of turning over the engine, the tension reading would be artifically higher, inflated by whatever "pent up tension" is in the belt, due to the manual rotation of the engine.
By turning it counterclockwise "anticlockwise", you make the other side of the belt the "tight side", and the side you're meauring is now the "slack side" That's what the factory tension specs are based on, measurements on the slack side.
SoCal Driver 01-06-2006 06:42 PM
I usually turn the engine over at about 5,000 rpm around tight corners in second gear to alleviate pent up tension.
