87 944s AFM
Recently I've been diagnosed with a faulty and/or knackered Air flow meter on my 87 944S. And have just seen an AFM on ebay going very cheap. Trouble is it's from a 91 Turbo. I think I read that there's a differance between pre 1985.5 and after on the AFM's. What i'm asking is is the 91 turbo afm compatible with my 87 S?
I've been quoted about £300 pounds for a reconditioned AFM and am looking at every alternative before I spend that much lol.
Cheers guys.
Old 01-13-2006, 12:40 AM
Eldorado's Avatar
they're different.
go here - http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=944M&section=fulint&page=2&bookmark=6&part_number=944-606-124-X-M263
only $162.50 with free shipping
that page also shows you the part number for the turbo. it's the entry directly above the one highlighted.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 01-13-2006, 12:53 AM
Thumbs up
Ah, cool. Thanks
Old 01-13-2006, 01:25 AM
SoCal Driver's Avatar
How was your AFS tested? You can open these up and relocate the contacts (wipers) on the carbon coated ceramic. See www.frwilk.com .
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Old 01-13-2006, 09:58 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
umm... either something's wrong with your link or frwilk has had a slight change of industry
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 01-13-2006, 10:17 AM
Looks like his web site has been hijacked!!!
Old 01-13-2006, 10:31 AM
winter-hater club member
nynor's Avatar
oh my!!!
"COOL PRIUS!" - Nobody Ever
Old 01-13-2006, 10:34 AM
strange, http://frwilk.com/early944/ still works, but it uses the hijacker's favicon.ico
Old 01-13-2006, 10:43 AM
This is the part of Wilks site that has the DME information:
http://frwilk.com/944dme/
Old 01-13-2006, 06:20 PM
Eldorado's Avatar
LOL
Wilk is FINALLY adding the "babe chip" to his inventory!!! I hear once installed, it immediately provides a digitally produced, yet fully tangible, sexy redhead in a short white tube top to wash your car.....
Kyle
Old 01-13-2006, 07:34 PM
patrat
Guest
Posts: n/a
I have one off of my parts car taking up shelf space; if you want it make a reasonable offer +ship. Unknown condition though, I bought the car with the timing belt popped. If there are electrical tests, I do have a multimeter to check it with.
Old 01-13-2006, 11:55 PM
Basicaly the car was running shoddy after the previous owner had fitted a new throttle cable incorrectly. So I took it to a performance car specialsit who re-set everything. And although the car ran better it still wasnt perfect. So I let him have it for a week as its worse when cold. He set it to the best he could (which is a vast improvement) but told me the afm wasn't working correctly. (the plasctic cover has had its seal broken when i was checking the car out at home after first getting it)
The symptoms of the car is, when first fired up, the car will not rev above 3000 rpm without spluttering like hell, when backing off throttle the revs will drop to 500, then sit at 800-1000. And the car is undriveable until it's warmed up for 2-3 minutes.
Whilst driving, car acts fine, unless say you're in heavy traffic crawling along at 15mph, using little revs. If you relase the trottle and engage the clutch, the revs drop again as if the engine is going to stall, then finds itself again at 800-1000.
Sorry about the lengthy post. And as this is my first, I really haven't a clue on my own lol. Its way different to dual SU HS4 carbs!
Old 01-16-2006, 02:41 PM
Patrat, what would you be willing to accept for the afm? If its in good working order. I'm in the uk so obviously there'll be shipping on it.
Is there any major differances between a euro and us spec afm? Example different DME signals or anything. Again sorry for the n00bish-ness of the posts.
Old 01-17-2006, 12:38 AM
FSAEracer03's Avatar
Send a message via AIM to FSAEracer03
Hey, when you have the AFM off, could you possibly do me a quick favor and measure the two dimensions of it's interior box? I wat to get a quick figure on airflow area.
I might be willing to snag that dead AFM from you, also ;-)
Kevin Reagan
1987 Guards Red 951 (Lorelei-- the 18psi temptress)
247whp/299wtq @16psi ...312wtq at 18psi, mmmm, torque!
Old 01-17-2006, 04:38 AM
Yeah I'll take some dimensions.
Am pretty busy with work (using the 944 every day) so I don't know when I'll get around to whipping it off, but I'll post em up for you.
Old 01-19-2006, 08:07 AM
Thanks man, I really appreciate it.
Kevin Reagan
Old 01-19-2006, 11:17 AM
