Send a message via AIM to skatman687
Angry Cooling Fans
I've recently come across a problem on my 86' 944. The cooling fan's run at full speed all the time when the car is running. I've never had a problem with over heating or anything like that and i've checked the water levels to make sure they weren't low. It never used to do this. I don't know whether it would be the relay or a stuck thermo-switch. The fan's run at full speed when the key is in the on position and when the car is actually running.
Any Ideas?
Old 01-26-2006, 02:33 PM
SoCal Driver's Avatar
Temp switch first. Big expensive relay second.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-26-2006, 02:37 PM
Non Compos Mentis
They come on automatically if the A/C is on.
Is your A/C on?
Old 01-26-2006, 03:14 PM
