Instrument lights went out and it isnt a fuse.
title says it all where do I look first? what wires?
Oh dear.
What year?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Could me the circuit board - mine has a short or break in the 'wire' that goes to the dash lights. I have a replacement board, but haven't installed it yet...
-Z.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Could also be the light dimmer switch, but it's best to get a voltmeter and start checking the wires. I would start with the dimmer switch and if I have power there, you should be able to see the color of wire leaving the switch and see if it doesn't run directly over to the instrument cluster. Hope this helps
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Its an 84. Well like I said the lights in the dash dont come on but the headlights still come up and turn on if this narrows it down any... so looks like I'll bust out the old voltmeter
84 944 You need parts let me know Parting out under the hood and interior |
the headlights use a different power source than the dash lights. check your running lights and your tag light.
86' 951 k26/27 hybrid turbo 01' audi s4 98' TDI jetta 96' 933tt AWD LS1 |
The reostat on the side of the headlight switch may be broken. Might be able to clean it with a shot of electrical contact cleaner as you move the wheel up and down.
