-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Engine build update (http://forums.pelicanparts.com/showthread.php?t=263613)
fast924S 01-29-2006 08:03 PM
Engine build update
Hey guys its been a while since I posted, Just thought I would update everyone on the status of project redblaze. I got some free time the other day so I spent most of it taking measurments of my engine, Bores/piston to bore clearences/Pistons/ rod journals ect ect, Everything specs out perfect with almost 0 wear which is sweeeet. Now I gotta order rings, Anyone know if total seal makes rings for the 944 engine?? I also have a mound of new parts that I need to install, First I gotta clean everything and figure out if I wanna do any head work. Anways I will keep you guys posted and start taking some pics of the new stuff.
pokey 01-30-2006 11:00 AM
I'm pretty sure I've seen Total Seals for '44s. I'll go through my bookmarks and see what I can find... It may take awhile, I have thousands of P bookmarks.
Zero10 01-30-2006 11:13 AM
There are total seal rings, but only the 2nd compression ring. It's either the first or the second, but I'm about 80% sure it's the second one.
fast924S 01-30-2006 01:10 PM
Hey pokey, Thanx for looking into that for me. I guess one total seal compresion ring is better then none. I have heard good things about the rings so I hope I get the same results. ANyone use them before??
Zero10 01-30-2006 02:50 PM
As for Total Seal rings ( www.totalseal.com )
First ring - not listed
second ring - T2166 - total seal
- CR2166 - conventional
They list them for street/track use.
So I guess you would buy a normal set of rings, then swap out the second compression ring from the set?...
pokey 01-31-2006 06:29 PM
Zero 10 beat me to it.
Zero10 01-31-2006 07:35 PM
Haha, I don't know if that is a bitter remark, or if I saved you time....
pokey 02-01-2006 10:06 AM
You actually saved me some time... Thanks!
