I might have to sell my beloved.
I think i may have to give up. I love my car. I can't afford it though and i feel like im letting it die. I need a new brake job asap, new timing belt replaced, and to fix a vaccum leak. I dont have the funds necessary to fix my car and it just gets worse everyday. Im thinking i should just give it to someone who has the time and money to work on her. I don't know what to do. I love it too much but soon i probably won't be able to drive it because it may kill me or be killed by me. Its a 944 83' with about 70k miles. Who wants it..Make an offer if you want.
1983 Porsche 944 |
Guess I need to create the Church Of The Lost 944 and take your car as a tax deductable donation.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Custom User Title
Brakes shouldnt be to expensive if you do it yourself.
For the timing belt find someone local who can help you out. Vacuum leak - give more specifics and someone here might be able to help out. If you cant afford to do belts or brakes on a 944 this really isnt going to change if you get another car |
I'm going to put a flag on my antenna at half staff. Sounds like a sad day. I second what DaveL said though. Get a second job...do something!
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
how many miles are you pushing? The belt you can get away with just doing the belt, which will prevent an outright snap and when you come into a bit more money than you can get it all done properly. Odds are the rollers will be ok. $30 belt and im sure you can get someone to do it for you for cheap from the boards. brakes will bite you a bit no way around that, but the vacuum leak will be like $3 when you figure out which hose is leaking. dont get rid of it unless you have to!
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
i did a full round of brakes pads and rotors on my car, using cross drilled on the fronts... and all added up cost less than $200 when my buddy did the work for me.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
