-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Is this a problem! (http://forums.pelicanparts.com/showthread.php?t=265242)
BjtheDj 02-07-2006 05:59 PM
Is this a problem!
Help me with this. While my car is parked, I turn my steering wheel to either all the way to the right or left and I hear this thump like sound. Sounds like somethings lose on both sides when I turn the wheels. Should I be concerned about this!
AFJuvat 02-07-2006 06:23 PM
Since this only seems to happen when you are at the steering lock, I don't think yo have a problem.
You may want to check your ball joints and tie rod ends just to make sure though
AFJ
Razorback1980 02-07-2006 08:49 PM
Do you hear the thump while you are turning or only at the end?
BjtheDj 02-07-2006 09:37 PM
I hear it when turning
earlr85944 02-07-2006 10:07 PM
try having someone watch the rack while you are turning the wheel, maybe they will see something loose
Razorback1980 02-08-2006 04:21 AM
If you hear it while turning, I think I would have it checked out by someone that can spot a faulty part. Sounds like you may have something loose or worn.
Slam 02-08-2006 11:09 PM
These guys have covered things pretty well. If it was me, I'd want to know where the dog is...
