Odometer not working after wheel swap
Hi all,
Last weekend I swapped my 15" Phone dials on my 86n/a for nice 16" ones from a 86 Turbo. Looks muuuuuuuch better. However, now my odometer stopped working. I changed the odometer gear a couple of weeks ago and it was working perfect until the wheel swap. Is there a sensor at the hubs or something? Anybody any ideas??? Thanks in advance!!!
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you... 1994 BMW 325is M-Technic 1986 Porsche 944 N/A |
On an early 944 I would look at there the cable comes through the grease cap on the left front wheel. On the later cars it's driven off of the transmission with an electrical sender.
Me thinks it's just coincidence. Unless your left rear wheel has permantly levitated off the road and is not turing.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
did you let the jack down?????????????????????
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Grrrr....I don't want to open up my dash again...Wheeeeee!!!!!!
OK, this is driving me insane...
I took the whole cluster out again (I get REALLY good at it), measured everything with a Volt meter, inspected the gears (inluding the new one from Rennbay) and couldn't find anything... The only thing I saw was a small pinch in one of the three wires, going from the print plate to the odometer motor. I wiggled those while measuring with a Volt meter and everuthing seemed ok. So I cleaned the contacts, put everything back together and it worked! However, this morning after approx 150 miles since repair it stopped again...grrrrrrrrrrr I have no clue what to do. My speedo and tach work perfect. It's somewhere in the printplate or the motor of the odometer... Any clues?
is this thing on?
86 is the later style speedo guys
"People willing to trade their freedom for temporary security deserve neither and will lose both" ~Benjamin Franklin |
It may just be the odometer motor. You can pick up used clusters on ebay for almost nothing. Buy one and swap the motor or the complete cluster. Save yourself the frustration. Actually pulling those isn't that hard once you get used to it, is it?
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
I totally hear ya....
![]() Yeah, I was thinking buying a used cluster and swap some stuff... Should I install these tacho rings? One side of me says it looks pretty good...My other side says keep it all original...Tough decision. What do you guys think?
