Corbeau seat brackets
Corbeau offers two different seat brackets for Porsche applications (from 1978 til mid-90s Porsches all seem to have the same adapters); one is listed as "Harness" for $65, and the other is listed as "seatbelt" for $79. I am assuming that this refers to whether you would be using stock seatbelts or racing harnesses; well, what is the difference in the seat bracket between the two. WHat changes in the seat bracket hardware from "harness" to "seatbelt"?
I actualy called and asked them about this because there was a pair of brackets on e-bay for cheap one time. The ones that say harness don't have the hookups for the seat belt. If you want to use your seatbelts then you have to get the ones labled that.
I used the harness ones in my car with my TRS's (with no harness). They work great. I don't see how the mount matters considering in the 944 the seatbelts don't mount to the seat bracket anyway!
Exactly. The "harness" version is straight up sliders only. I put harnesses in my car so the seatbelt was removed from the factory seat and drilled through the tunnel.
i think i might just use Tifosiman's bracket-fabrication process, but thanks for the responses :)
| All times are GMT -8. The time now is 05:04 PM. |
