-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Vacuum line help needed (http://forums.pelicanparts.com/showthread.php?t=270933)
tim944 03-11-2006 05:41 AM
I could really use some help with my vacuum line situation.
I had the head redone and have everything put back together. It runs very rough and I think it is a vacuum line. It idles at the correct RPM but not very smoothly. It seems to smooth out when the RPMs increase. I,ve double checked all the connections. I'm fairly certain I have them right (I have the shop manual) but not 100%.
Can anyone tell me where and how much vacuum I should have at the various connections?
SoCal Driver 03-11-2006 09:22 AM
Alos check the diagram in the silver sticker on the passenger side front fender in the engine compartment.
tim944 03-11-2006 07:49 PM
I checked the diagram under the hood. As far as I can tell it looks right. What I don't understand is that it ran fine just before the head gasket went bad. I'm having a tough time trying to figure out which each vacuum line does and which one could be the culprit. I may just replace all of them.
tgcattle 03-12-2006 06:23 AM
pelican oughta make a kit for replacing all the vacuum lines
tim944 03-12-2006 06:44 AM
What would be helpful would be a better diagram that showed actual positions or maybe some good pictures. Or maybe something with a discription of how each vacuum operated component worked. If I get this figured out I may have to do that.
Does anybody have anything like that?
livewirevoodoo 03-12-2006 07:21 AM
http://clarks-garage.com/graphics/na...uum-line-1.jpg
http://clarks-garage.com/graphics/na...uum-line-2.jpg
sayporsha 03-12-2006 10:34 AM
If you can't find a vacuum leak you should check to see if the cam timing was set correctly. If the timing belt is 1 tooth off it could cause this condition.
tim944 03-12-2006 12:03 PM
I got it! Thanks for your help guys. Here is what I found:
Balance shaft timing off 1 tooth on top side.
Vacuum line clamp loose on idle control valve under the manifold.
#3 fuel injector connection not making very good contact.
She purrs like a kitten!
Thanks again. I don't think I could keep this car going without this board.
