Blocked injectors
Do 944 injectors need cleaning on a regular basis?
Ran some injector cleaner through mine last summer and i'm going to do the same again now as i suspect they may be blocked (every now and then i can smell fuel and she will run a little irratic at about 2500rpm in 3rd or 4th in town driving (not noticable at speed or open road).
Does anyone clean them on a regular basis and would faulty injectors be noticable only at idle or throughout the driving range?
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 03-24-2006, 05:25 AM
If your injectors are that old I'd think about sending them off and have them professionally cleaned. I did that with mine several years ago. It made a difference for me. Caveat: Your mileage may vary.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 03-24-2006, 05:41 AM
Hi lawrence, what were you symptoms?
Old 03-24-2006, 06:08 AM
Slight uneveness during light acceleration even after new rotor, plugs, wires, distributor cap. Plus, the car had about 140K on it at that time, and I assumed PO did not do it. I had put about 50K on it myself by that time.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 03-24-2006, 10:19 AM
Eldorado's Avatar
i run a couple bottles of injector cleaner a year...
failing that, i'll fill up with the high-test gas with the injector cleaner addative maybe once or twice.
what octane of gas are you using in your car?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-24-2006, 10:29 AM
98 ron mostly.
Wonder if any condensation from the petrol tank in cold weather would work through to the injectors.
Old 03-24-2006, 11:08 AM
Eldorado's Avatar
that's the problem right there.
the guys will correct me if I'm wrong, but constantly running a higher octane will actually create carbon deposits...
I believe 98ron is about 91-94 over here in north america... and that's too high.
i'm sure the guys will chime in if I'm wrong..
Kyle
Old 03-24-2006, 11:14 AM
Cheers Eldorado,
carbon deposits on the plugs or on the pistons?I am due a plug change actually.
Regular unleaded fuel over here is 95.
Old 03-24-2006, 11:22 AM
