Welding question
The collar on my balance shaft that holds the power steering pump broke and I would like to see if it could be welded back on. I am wondering if there are places that will weld it while it is on the car or do I have to take the whole balance shaft mount out? Any experience with this?
Dan
1988 Turbo S (Red)
2005 Acura TL Black [Totaled]
2008 Grand Cherokee Overland (Black)
http://i25.photobucket.com/albums/c9...S/dsc_0437.jpg
Old 03-31-2006, 09:50 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Hey Dan,
Do you know what type of metal this is? If it's cast aluminum, then someone with a tig welder/heliarc/even a mig welder with the right setup could do the work, but I'm not sure if they will do it that close to a fuel line or not. With the right mats and things a professional would have, they might be willing to do it. Take a picture and head to a welding shop and take the broken piece with you and see what they say. That's the only way to find out for sure.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-31-2006, 11:04 AM
and don't forget to unplug the DME unit if your are welding on the car
Tom
Early '85 944
Old 03-31-2006, 11:36 AM
Send a message via AIM to Jmasters
its aluminum
and yes i probably could be welded, but have it TIG Welded
its much stronger of a weld
btw, i TIG weld aluminum at work building custom Intercoolers
and it would be best to take it out of the car, makes it much easier to get it welded on a bench than on the engine
SOLD 1984 944 NA, Fr Wilk PowerProm, rebuilt engine, blisten shocks front and rear, 220lb springs, adjustable 968 rear sway bar SOLD
Old 04-01-2006, 09:23 AM
I know but trying to avoid taking it out dut to time constraints. I have gotten a replacement so if I am gong to take it out to be welded i would just replace it. Trying to buy some time.
Dan
1988 Turbo S (Red)
Old 04-01-2006, 09:29 AM
gearhead290's Avatar
Send a message via AIM to gearhead290
You're talking about the adjustment bracket for the PS pump right? I had the same problem happen on mine many years ago, take the eyelets that go around the bolts (know what I"m talking about? They're similar to a heim joint). I then took a pipe that I cut to a certain length, you have to have it on the car to figure this out. I then used an oxy acetalyn (sp?) welder and just melted a hanger into it. The peice is awfully heavy to be aluminum, and tig welding it is overkill. This peice does not have a lot of force put on it.
Basically, any mechanics shop should be able to do this w/o a problem. If they can't do it, find a new mechanic.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 04-01-2006, 05:05 PM
Talking about this piece
that goes here
which is also here:
Dan
1988 Turbo S (Red)
Old 04-01-2006, 06:30 PM
ooo...that's aluminum. I was thinking about the adjustment peice that goes up to it. Just take it off the car and then take it somewhere people weld aluminum. What caused it to break? Stuff like that doesn't just break, there's usually a cause.
Old 04-01-2006, 08:12 PM
