Top Question
Hi All,
I am enjoying my "new" 944. I have pretty much sorted out everything the previous owner didn't disclose. I'm down to the last couple of things (that I know of.)
How do you remove the top? The PO has the bolts that go through the clips then the vinyl trim in between the trim and the metal top.
I need to remove the top to get everything back together right, but cannot figure out how.
Thanks!
86 Porsche 944 NA Guards Red
89 BMW 325is (Euro Spec) Red (SOLD)
04 Triumph Bonneville America MC
Old 04-05-2006, 03:50 PM
91S2's Avatar
If you're just looking to take off the sunroof, turn the ignition to "position 1." when you push the sunroof swith it will retract the arms and enable you to take it out....unless you're gears are messed up or something.....if you need more help, for this and most any other topic you can do a key word search in the forum. there's some threads out there already
1991 944S2 Guards Red
Old 04-05-2006, 08:08 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
If the gears are not working, here is an article to read:
http://www.pelicanparts.com/techarticles/944_Sunroof/944_sunroof.htm
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 04-06-2006, 08:19 AM
