Virginia Rocks!
VaSteve's Avatar
What is this gasket set?
I got a couple of gasket sets with the new engine. One was labelled as a head gasket kit. The other, obviosly is the oil pan, but there's a bunch of other stuff in there as well. Is this a front engine kit I'm looking at? (water pump, balance shaft seals, etc.?)
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 04-14-2006, 08:02 AM
Here is a engine seal kit. it includes
1 cam seal (one of the red seals)
1 cam o-ring (the black o-ring on the right)
1 distributor housing to cam housing seal (small white seal bottom right)
2 balance shaft seals (2 of the red seals)
2 balance shaft housing o-rings (two black 0-rings in the middle)
1 front cranshaft seal (the black seal)
1 front crankshaft o-ring ( the green o-ring)
3 mylar washers ( the three clear washers you can barley see bottom right)
it looks like you are missing one seal, the mylar washers(cant tell from the pic), the distributor housing to cam housing seal and the cam o-ring, and the rest I dont know.
86 Red 944(sold)
85.5 Red 944(sold)
Old 04-14-2006, 10:24 AM
The pan gasket set includes the front seals and the oil cooler seals. They are not labeled and the NA cars do not use all of the seals that are in the kit. Be careful to compare the new with the old and you will be OK.
Old 04-14-2006, 10:33 AM
