Emergency Brake Help
I am replacing my emergency brake pads and am having trouble installing the top spring. Are there abny tricks to this? The bottom and side springs are already in aw well as the adjuster. Theother option is to have all the springs in and then spread the pads and insert the adjuster but that is difficult too. Any advice?
Dan
1988 Turbo S (Red)
2005 Acura TL Black [Totaled]
2008 Grand Cherokee Overland (Black)
http://i25.photobucket.com/albums/c9...S/dsc_0437.jpg
Old 03-25-2006, 04:09 PM
callmethewander's Avatar
nice one
i saw a real nice, black 944S up near Harriman state park in rockland last sat. were you in the neighborhood? sry i can't help w your brakes but i don't know.
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 03-25-2006, 07:08 PM
Re: nice one
Nope wasn't me. Don't worry about not beng able to help. I figured it out.
Dan
1988 Turbo S (Red)
Old 03-25-2006, 10:17 PM
cool. i have to replace my rear rotors, is there anything i should know about the em. brake stuff that might be a problem?
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-26-2006, 06:57 AM
First I attached the pads to the car using the push springs. While doing this you have to install the bottom spring. The hardest thing was that top spring. I installed the adjuster first. then i bought a drum brake spring tool. Like a bid plier. ONe side hooks onto the spring and the other you can brace against the pad. It stretched the spring so i wa able to get the hook to the hole but it didn't seat it around the back of the plate. Used a punch to drive the hook arround the plate.
Dan
1988 Turbo S (Red)
Old 03-26-2006, 07:08 AM
Send a message via AIM to yieldsign2
Dan,
Could you explain the process of getting the pads OFF? I can't figure it out...
1985.5 944 NA
Old 03-26-2006, 07:22 AM
The emergency pad? I took a screw driver and pushed in the springs on each side of the pads. When you push in and turn they will detach from the back. It is then easier to maneuver the pads off.
Dan
1988 Turbo S (Red)
Old 03-26-2006, 08:03 AM
so are those springs that stick out towards you part of the pad? Do you have to unhook the springs that connect the pads to each other, do you have to disconnect the adjuster.. etc?
thanks
1985.5 944 NA
Old 03-26-2006, 08:46 AM
auh auh is offline
auh's Avatar
Send a message via AIM to auh
Where did you find the pads for and for how much?
When I worked at Porsche last summer I was told its the same pad used in the 996 and 986 and with my employee discount it was going to be over 100 a pad
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 03-26-2006, 11:16 AM
I think the pads can be found at **********.com, and probably paragon and pelican for around 100-115 a SET I believe?
Or.. i have some used ones in decent shape.
1985.5 944 NA
Old 03-26-2006, 12:17 PM
YOu guys are going to be jealous. I called my local Porsche/Volkswagon dealer. Porsche parts was closed but the VW parts guy said he has access to Porsche parts if I had a part number. Gave him the part number he looked it up and had one set left. Called me back after he went to make sure he had it, said he had it in his hand and it was.......are you ready......her goes......Hope you are all sitting.......$45.00. I ran over and picked them up.
yieldsign2 - Not they are not part of the pad but they do hold the bad to the car. I found after you undo the springs it is easier to take the rest apart. You are going to have to at least take the top spring off to get the pads off. When you do that is sort of disassembles itself.
Dan
1988 Turbo S (Red)
Old 03-26-2006, 02:14 PM
ok, but do you have to do any of that if you are just replacing the rotors, or can i leave the whole parking brake system alone as long as the pads are not too worn?
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-26-2006, 04:26 PM
If you are just replacing the rotors you don't need to bother with the emergency brake pads at all. The rotor fits over them. Just make sure the emergnecy brake is off when you go to take the rotors off. If they are on you can pull pull and pull and you will curse curse and curse and it won't come off. (Ask me how I know)
Dan
1988 Turbo S (Red)
Old 03-26-2006, 06:03 PM
Granite 944's Avatar
Jeeper. You go from one problem into another. Do you have access to Clark's Garage? Maybe to a copy of the FSM. Maybe your just really, really lost at everything you do? Whats up with this? Most of what your asking, REALLY isn't THAT big a deal. I'm sorry, butt, whats up with you? I don't know, maybe I'm mixing up more than one "Jeeper"?
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 03-26-2006, 06:10 PM
First of all it seems I am the one doing the helping here. My second post said I figured it out. Second of all if you do not like the questions I ask and you do not want to help then please don't reply. Maybe you should also look at clarks-garage and see that what I asked here is not covered there. Please refrain from posting in any of my threads if you are not willing to help. Thanks
Dan
1988 Turbo S (Red)
Old 03-26-2006, 06:22 PM
thanks jeeper
1989 S2
1988 S
1987 944 n/a (sold)
Old 04-14-2006, 03:56 PM
and whats with granite, geez?
1989 S2
1988 S
1987 944 n/a (sold)
Old 04-14-2006, 03:58 PM
No problem. Haven't figured him out yet. Hope I don't have to.
Dan
1988 Turbo S (Red)
Old 04-14-2006, 07:32 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Granite, I second that. You are rude and unhelpful....why are you on here? All your questions and comments are ...you people should help yourself. I am kind of guessing here, but I really don't think many would help you even if you posted something, so maybe your time could be better spent doing something other than reading this. Perhaps you should take up knitting or something.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 04-14-2006, 09:54 PM
Eldorado's Avatar
it's funny because I dont think granite has any real knowledge of these cars...
whatever the case, I'm sick of the "holier than thau" attitude.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-14-2006, 11:05 PM
