Window Trouble
Two problems
1. I cannot roll the pass side window up or down from the pass side it only works from the drivers side. Also sometimes once down it will not go up for a few min after a few tries, I think it may be a bad connection.
2. Yesterday I was rolling down the pass window and I heard a bang from the door. It sounded like the window came out of it's track and fell. The glass looks to be ok.
How should I go about taking care of this?
83 944na
Old 05-22-2006, 11:33 AM
First thing you need to do is open up the door panel and see what you can see. It might be obvious, but you dont know until you look at what is going on in there.
86 Red 944(sold)
85.5 Red 944(sold)
Old 05-22-2006, 11:36 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
If it's like mine the actuator broke and needs to be replaced. Take the door panel off and look, but i'm guessing it's time to buy a window actuator.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 05-22-2006, 11:37 AM
what is a window actuator?
83 944na
Old 05-22-2006, 02:22 PM
Eldorado's Avatar
the motor that pushes the window up and down...
my vote is on the switch.... switch the passenger side switch with the drivers side *drivers window* (provided THAT one works) switch, and see if that helps.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 05-22-2006, 03:06 PM
try cleaning the contacts on the switch with somethin that can access the contacts, ie a flat head screwdriver and scrape the surface to make it shiny. do this for all contacts and ur switch is good as new. with the window clunk noise, take off the door panel and check out whats goin on. Could be that the window fell off the reulator, or the actuator's broken as it has been mentioned. Check and see if all the hex bolts are in and everythings tight and aligned.
1984 Porsche 944
Old 05-22-2006, 06:22 PM
Thanks guys I am going to open this baby up and I will let you know what I find
83 944na
Old 05-22-2006, 09:01 PM
I think I need a new switch.
83 944na
Old 05-23-2006, 06:24 PM
Eldorado's Avatar
what makes you think that? did you swap them around and find it worked alright?
Kyle
Old 05-23-2006, 07:08 PM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
It helps to clean the connectors too
keep the dream alive!
1988 944 NA (purple)
Old 05-23-2006, 08:15 PM
