Brake pad retaining pins seized?
I can't seem to get the Brake pad retaining pins out of the right rear caliper. They are not supposed to be that hard to drive out, I have hammered away at both until they are both starting to get flat at the tops. I used PB blaster for 2 days now and they won't budge. I was thinking of grinding off the flatened part down to the caliper body and drill out the rest but they look like they are made of pretty hard metal. What to do ?
Mark '86 944NA '10 VW Golf 2.5 5sp '99 BMW 540i Sport Wagon |
Carbide drill bit. Cuts through hard steel like it was clay. Don't drill the holes over size.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
