Cruise control overrevved!
I was on one of those high-speed roads with occasional traffic lights and when the light turned red, I shifted into neutral in preparation to stop. Didn't realize the cruise wouldn't disengage in neutral and the engine spun into the stratosphere! :eek: I don't know why I didn't just think to touch the brake pedal, but in full panic mode, I killed the ignition and coasted down. On restart, everything ran OK, no nasty noises, and the engine runs fine now. I assume there's a rev limiter, and if I hit redline, it wasn't for more than 1 second. Anyway, is there anything I should do or check at this point, like the timing belt tension? The timing belt has probably less than 1K miles on it now.
As long as it wasnt a downshift, the rev limiter should have prevented any damage being done to the engine. If you downshift and over rev the engine, the rev limiter dosent do anything.
I wouldnt worry about it.. i have tapped the rev limiter on more than a few occasions (autocross). Still running strong... ::Knocks on wood:: You should have your timing belt retensioned soon anyhow.. supposed to be between 1000-1500 miles for a new belt. Besides, its good to give the car a good Italian tune up every once in a while.. need to burn off some of that carbon buildup you know.. :). |
Interesting...
Mine only engages ABOVE 80 MPH... |
Mine will engage at 20mph if I use it, but it cuts out as soon as I press on the clutch or the brake.
Sounds like your clutch switch is shot. |
the person that had the car disconnected mine cant wait to find out why once the motor is hooked back up
LOL!!! There's a rev. limiter. Assuming it's working properly you've got nothing to worry about.
Just a heads-up, in a lot of states it's actually illegal to coast in neutral. In any case, it really isn't the best driving technique. |
How can they prove you were coasting in nuetral, when you actually could have been in gear with the clutch in? oooooooo...
not sure i want to put all my faith in the overspeed limit capabilities which is protection in a loaded condition. 87951 |
The system functioned as designed. The fault was in the driver. |
Haha yeah I kinda did the same thing before in an old Fold conversion van. The cruise control got stuck on at 70mph, and I couldn't turn it off by pushing the brakes or the button. I was left with the only choice of throwing it into neutral, at which point I thought my engine was going to explode like you did. I also killed the engine, but that made it very difficult to maneuver the beastly vehicle around the traffic jam that I was quickly approaching :eek:
I would think that everything would be fine with your engine, assuming that your rev limiter is functioning properly. Definitely won't be making that mistake again now will you ;) |
why would it be illegal to coast?
I tested mine, and it doesn't re-engage when I release the clutch, in gear or in neutral.
Either somebody already tweaked the clutch switch wiring, or mine's just plain broken ;) |
| All times are GMT -8. The time now is 05:13 PM. |
