alternate fuse box location? A/C
When discussing issues with the A/C the 'alternate fusebox' always comes up. What is the location of it?
Thanks,
-Alex
-1987 944 N/A
Old 07-05-2006, 10:57 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
If there is an alternate on the later years, I'm not aware of it. I "THINK" there might be fuses and relays in different locations on the early years but I'm not certain as I've never owned one. I see you have an 87, so I think you should only have one.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 07-05-2006, 11:45 AM
SoCal Driver's Avatar
Early 944's and the later 924S's only. From 85.5 all 944's have the large combo fuse and relay box under the hood. A much better idea.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-05-2006, 12:01 PM
