self adjusting pedals
hey all,
I noticed since i started takin my 944 out this spring n summer that the brake and clutch pedals become very stiff after being driven for a while. Duno what could be causing this, is this normal for 944s? it even gets to a point where i lose acceleration. What should i do? Im sure its due to the fluid expanding in the warmer temperatures but the stiffening makes me worry somethins wrong. Thanks in advance.
1984 Porsche 944 |
Back from Beyond
My clutch does this, too. I'm just going to adjust the freeplay in the pedal, partly because I put in a new slave cylinder yesterday. However, I noticed the same change in the friction point before the repair, and it did seem that temperature affected it. I think stock pedal freeplay should be about 3mm - maybe I'll go for a bit more in case fluid expansion ends up putting preload on the slave cylinder.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Back from Beyond
Hey, bigbird944, an update for you.
I adjusted my clutch pedal freeplay and that cured the problem. Chances are this fix'll work for you in this case.
