I may have to replace the head on my 944. Does anyone know what heads are compatible with an early 1985 944 N/A?
It's rare that you would need to replace a head unless it's been really overheated and cracked or it's been machined to the point where there is no room to clean up the mating surfaces. Sorry, I don't know which ones are compatible with yours but I think most NA heads are the same. But someone here will know for sure. Send me a PM if you need to find one and I'll help you.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
I can tell you this. and 85.5 Head will fit on an 83 :P
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
Back from Beyond
N/A heads, excepting the S cars, are pretty much interchangable. The later ones had an oil check valve to prevent the lifters from losing too much oil after shutdown. It's an easy job if you're comfortable doing your own timing belts.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
easy and all 8v heads interchange (other then the 2.7 irrc)
87 951 |
