Graduated User
conkeytonk's Avatar
Screwed up
Is there a better solution for attaching the rotor to the camshaft extension? My 3mm Allen screw was stripped. Got it out but want to replace with something that wont strip next time. Clark (of Clarks Garage) claims to have seen many of these little menaces stripped.
Randy
1977 Scirocco Rebuilt 1.7L Stock Grey (Totaled)
1979 Scirocco Built 2.0L Stroaker Blue (Pilfered)
1979 Scirocco Built 1.8L Rust Bucket Tan (See ‘ya)
1982 Scirocco Rebuilt 1.7L Garage Kept Gold Daily Driver
1987 944 NA Rebuilding 2.5L One Female Owner Grey Weekender
Cruising to a conkeytonk in my Scirocco on steroids
Old 01-09-2007, 01:41 PM
Quality
phoenix_iii's Avatar
If you read clarks-garage, you know...
"Removing the Rotor
1. To remove the rotor, you'll need a 1/8" or 3 mm hex key. Try the 1/8" first and if that's too big, next try the 3 mm. If it's the original screw and you try the 3 mm first, you'll likely strip the head on the screw. The original screws are slightly larger than 3 mm and they are loctited from the factory. I can't begin to tell you how many of those I've seen stripped using a 3 mm hex key. Anyway, if the 1/8" doesn't fit and the 3 mm does, it's probably been replaced in the past (because it was stripped). "
It's NOT 3mm... it's (originally) 1/8''. and loc-tited to boot. 1/8'' ftw.
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 07-15-2008, 07:02 AM
