951 Parking brake adjust help
951 P brake lever goes to the roof before brakes grab. Following shop manual instructions which say to put screw driver into hole in rear brake disc and turn adjuster, I looked in there with flashlight but can't see anything to adjust with the screwdriver - stumped, any help appreciated.
Just checked Clark's garage website, same procedure outlined. I can see inside the hub just fine - I see springs and the like for the drum brake but nothing to adjust with a screwdriver. Thanks again. Last edited by 74goldtarga; 09-02-2006 at 04:03 PM.. |
Items 17. Left is the star adjustor nut.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Thanks, the wheels go back off Monday and I'll see if I can identify part 17.
Rotate the hub putting the large hole at the top. Use a flash light. You should see the "star" edge on. You need to move it's lugs up to tighten the shoe brakes. Adjust till you can't rotate the hub then back off till there is no scraping noise from the shoes. Might be a bit of pad scraping.
