Interior Adhesive
I need to repair some of the leather interior on my 944S2 - it has detached from the metal. Any suggestions regarding what to use? The current stuff is semi-tacky so you can remove/replace interior without damaging the leather.
The unexamined life is not worth living. -
Socrates
Old 09-23-2006, 10:06 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
3m General Trim Adhiesive or is you are parinoid the super version of it
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 09-23-2006, 10:15 AM
Thanks for the suggestion. Researching the 3M site yeilded two products, one with high strength and one with lightweight strength designed to be used in conjunction with a mechanical fastner.
In my particular application to reattach the headliner around the sun roof, there is a piece of weather stripping that aids in holding the headliner in place.
The high strength product is 3M Id : 60-9800-4516-9.
The lightweight product is: 3M Id : 60-9800-4439-4
Socrates
Old 09-26-2006, 12:00 PM
