Oil flow
I didn't have much luck on the 951 or Clark's forum let me try here. I'm installing a 951 oil cooler housing in my NA. I'm also installing an aftermarket oil cooler. There are 2 fittings on the housing, one is just under the filter and the other is on the side. I'm trying to figure out which of the fittings on the housing is the "oil out" and which is the "oil in". Can anyone help?
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
Don't Know the 951 but here's the 968 for Reference.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles |
So from that pic I see the flow from the oil cooler is under the oil filter?
