Send a message via Yahoo to bobp53916
Fuel problem
I tried to move my car out of the garage today after work to do some cleaning and it wouldn't start, I checked the fuel rail and theres no fuel and had a friend listen for the fuel pump running and nothing, I tested the fuel pump and that works and I checked the fuel pump fuse and it looked good but changed it with a new one anyway. The car is an early 85 944 N/A, my question is which relay is for the fuel pump? I figured that would be the next thing to check and I did some searching and found nothing really about an early 944 fuel pump relay location. And is there something else I should be checking? The car ran fine when I parked it 2 days ago. Thanks in advance for any help...
Old 01-10-2007, 09:10 PM
Send a message via AIM to AznDrgn
The fuel pump is controlled by the DME relay, IIRC it's the second one from the left on the top row. The relay should say DME right on it. Search DME jumper and you'll find out how to make a test jumper to bypass the relay and see if that is your problem.
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 01-10-2007, 09:22 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
clarks garage also has a detailed explanation as well.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-10-2007, 11:17 PM
