Writer/Teacher
951 Exhaust
I have a straight-pipe 951 exhaust that I bought from my mechanic back when I was going to attempt a turbo engine project. It is a cat-delete pipe, which goes in after the headers and goes up to the pipe before the muffler.
My question is whether or not any section on the stock car is welded; in other words, would I be able to jack up my car and pull out the necessary section and replace it with the aforementioned exhaust relatively quickly?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Writer/Teacher
Here's a pic of the exhaust-in-question. It is the one on the left (obviously).
CJ i did a similar job on my car when i first got it. only i put a stock muffler back in, then had to ADD a cat, its an NA,. all the parts were just bolted up in sections, take one section down replace. just remember the metal gaskets that go inbetween each section. they are large rings that sit on the inside flange of where the flanges meet.
1995 993 C2 |
Writer/Teacher
Thanks for the response. I assumed that the pieces were just bolt-in.
I figured since it finally snowed here in CT, I might as well tinker with the 951 in the garage a little. I figured I would install the coming chips and the LBE, and jack up the car and install the exhaust. If I don't like it, I'll just go back to stock.
