what are the odds???!!!
What are the odds that the seal in my rebuilt water pump would go out after 5 days of driving, and then my replacement BRAND NEW pump's seal would go after two weeks of driving? Is there anything to do with my car that could contribute to these faliures?
-Gabe -black 1988 924s, 944 turbo sway bars, LSD, gunmetal phone dials-- SOLD to some people who cannibalized her -1987 MR2 ---ONLINE REP FOR RADMACHER PORSCHE SERVICE IN TUCSON--- |
Greasy Member
Sounds like the timing belt may have been installed to tight.
Did you do it yourself, or have a shop install them? -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
My boss who works on Porsches day and night did the tensioning and he for sure tensioned it to spec for a new belt- 4.0 on the special tool.
My first guess was belt tension, but it sounds like you are OK on that. Sediment in the cooling system is a possibility. You may want to flush everything out (including the heater core). Also, antifreeze lubricates the pump, so if you aren't using any antifreeze, you may want to add some. Make sure it is the correct type. Cavitation can tear up pumps. Make sure the system is bled correctly and that the thermostat is opening properly. Karma - might want to check off an item or two.
