-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   what is the trick to getting the spring loaded (http://forums.pelicanparts.com/showthread.php?t=333924)
nynor 03-05-2007 06:51 PM
belt tensioner off? i need the thing off, i believe to change the timing belt.
thanks!
SoCal Driver 03-05-2007 06:55 PM
Loosen the bolts at the piviot and at the slot, pry the arm back and tighten it.
nynor 03-05-2007 07:01 PM
yeah, i did that. don't i need to get the thing entirely off to change the belt?
Techno Duck 03-05-2007 07:06 PM
Three nuts hold it onto the block, it slips on over studs. Use an inspection mirror to figure out where they are.
nynor 03-05-2007 07:09 PM
oh boy. i need a mirror for this? thanks!
Techno Duck 03-05-2007 07:27 PM
Its not they are hard to reach, its just they are hard to see due to the position. Of course you could take the radiator and the fans out for a clear shot.
nynor 03-05-2007 08:05 PM
i think my last post sounded bad. thanks for the information. i'll take a look tomorrow.
SoCal Driver 03-05-2007 10:58 PM
Compress the arm and tighten it. Take the idler pulley off -- one bolt. Release the tension on the arm. You do not have to take the arm off. Don't loose the special oblong washer or put it back on wrong -- there is an indexing tab that locks the oblong washer into the casting.
With the tension off of the arm you can get to the three bolts that hold it on.
bazar01 03-06-2007 04:59 AM
There are three hex nuts holding the tensioner assembly to the block.
Do not compress the tensioner yet until you have removed the hidden nut beside the tensioner roller.
Remove the hidden nut first, then compress the tensioner, then remove the other two nuts holding the tensioner assembly.
Then you can pull out the tensioner assembly.
SoCal Driver 03-06-2007 07:39 AM
IF you can get to the "hidden" retainer with out releasing the tension on the arm.
nynor 03-06-2007 10:07 AM
ok, just to be sure: do i have to remove this part to replace the belt?
HondaDustR 03-07-2007 06:14 PM
You don't have to, as long as you compress it far enough to leave enough room to work the belt out.
SoCal Driver 03-07-2007 06:22 PM
And take the pulley off the end of the arm.
Techno Duck 03-07-2007 06:32 PM
I am a 'veteran' of 6 belt jobs now, let me just say its alot easier to get the old belt off and the new one on by taking the tensioner off. Its only 3 nuts.
SoCal Driver 03-07-2007 06:53 PM
Never said NOT taking the whole unit off was easier. Trying to answer a thousand questions. Time to cut bait.
Techno Duck 03-07-2007 06:59 PM
I didnt mean that towards anyone. I was just simply saying in my experience its much easier to just take the entire thing off.
SoCal Driver 03-07-2007 07:06 PM
I've seen newbies take the whole thing apart with the spring and arm flying off to hide in dusty corners. Also over compressing the arm so that it covers one of the three studs/nuts and using a pry bar because it's "stuck". Just don't loose the obround washer and put it back on correctly if you do.
nynor 03-07-2007 07:40 PM
ok. i have to change the roller as well. they are all worn. how about just taking the roller off and leaving the rest of the assembly attached? or will that be an even bigger PITA?
Razorback1980 03-07-2007 07:56 PM
It's been my experience that removing the whole assembly is what worked best for me.
Techno Duck 03-07-2007 07:59 PM
Seriously, just take the damned thing off! Its 3 nuts!
You need to hold a bolt on the opposite side anyhow.
