electrical issues
thanks, all, for your ideas on why my radiator fan would not shut off. I'll check out the thermo switch on the radiator. I'm having some other electrical issues, and I'll spell them out here - maybe they are tied together somehow -
- power sunroof - works somedays, but two times - nothing at all when I press the switch. Yesterday it worked - turn signal relay started buzzing last night and wouldn't stop - I had to pull it - wiper fluid doesn't squirt when lever is pulled - my mechanic said the motor is not getting any electric signal - previous owner had replaced the radio with a Blaupunkt CD player, but couldn't get the antenna to pop up when the unit was turned on. I see that the rad fan and the antenna are on the same fuse. Could my problems with the rad fan and the antenna somehow be related? thanks, Bob Last edited by bboross; 03-11-2007 at 07:15 AM.. |
Sounds like you have spotty relay contacts - you may want to check your relay panes.
No voltage to the washer pump - bad fuse or the switch is bad.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
