-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   weird spring noises (http://forums.pelicanparts.com/showthread.php?t=337235)
amunoz3 03-22-2007 10:44 PM
weird spring noises
Their is weird spring noises on the 944 you can hear it while moving and a little more when i press the brake.
Eldorado 03-22-2007 10:51 PM
ok?
where are the noises coming from? is it a squeal? a creek? we need more to go off of here...
amunoz3 03-22-2007 11:03 PM
it sounds like its coming from underneath the front of the car but since its only happening when the car is moving its hard to determine but it does sound like springs rubbing together
944cabby 03-22-2007 11:30 PM
On my 924lux when i first bought it you could hear the springs on braking or a hard turn - it was like a creaking sound - had it in the garage and it turned out that both inserts in the shocks were the originals (over 100k on the clock) and completely knackered.
Noise went away when the new inserts were fitted.
