quick cluster gauge question
I have my steering wheel removed and all the screws removed, i just cant pull out the gauge cluster far enough to remove the wires that are holding it in. any other way i can reach the wires?
Porsche 1984 944 '94 Ford f250 Diesel |
That Guy
You can reach up under the dash and disconnect the connectors and speedometer cable. You will probably have to get on your back and look straight up.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Have to take the top cover off of the turn signal switch unit. Be careful not to strip the screws or break the cover.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
my computer is blocking me from reaching up there. but i was able to see that i have enough wire slack to pull it out, so what else would be holding me in? i have already removed the steering wheel and switch unit.
stiff speedo cable i'd imagine.. or if someone installed a dash cap, it could be blocking it.
there are two screws on he left and right clusters (top)... the DME isn' really blocking... you have to reach up between the DME and the driver's side door... up and around.. I tried it and found it to be quite simple.. try pushing the cable for the speedo through the firewall a little more from the engine bay to give you more slack.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
winter-hater club member
pull the computer. 4 screws, one clip. this will make your life a lot easier. undo the speedometer cable from underneath.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
well thanks for the help. gonna try and get out there when its reaches todays high of 35f. for upstate. thank god for global warming
