adhof55's Avatar
924S clutch problem
HELP! This is the first Porsche owned 1988 924S. The clutch pedal works sometimes and sometimes it will stay to the floor. The car is a project for my son and I. The car had a fried engine block and wires. Replaced the engine and wire harness and clutch, got the car to run with the replaced engine. I am just finishing up with the loose ends.
924s, 1988
RX7, 1980
Riviera, 1996
Old 04-18-2007, 04:39 PM
Eldorado's Avatar
get a new clutch master and slave cylinder, bleed the clutch.. go on a nice drive.
whole process, minus the nice drive, should take about 3 hours with breaks, depending on how seasoned you are..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-18-2007, 04:52 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
...or you can just try bleeding the cylinders you already have, but don't be surprised if you have to replace them. Look for brake fluid in the drivers floor board if the master is leaking or brake fluid on the pavement if the slave is leaking.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 04-18-2007, 05:07 PM
Eldorado's Avatar
hey tom, to that end... my fluid level is still same as it's ever been, but I've got the sloppy pedal syndrome again indicating that one or both the cylinders are shot..
I looked at the boot on the mater cylinder... and it was shiny and covered in brake fluid... what would cause the boot to be covered like that?
Kyle
Old 04-18-2007, 07:06 PM
