clutch leaking
So i started my car up to put it in the garage, and i noticed (not as quick as one might think) that my clutch pedal was on the floor, no pressure. i turned it off pushed it forward and noticed a small puddle of fluid (where the car had been), i pulled the pedal out started it up and drove the car into the garage. after jacking it up i saw the same fluid leaking out of the clutch test whole. the break fluid reservoir is 3/4 full and i drove the car a couple of blocks making sure it was all ok. Now i know all of this is warning me that something is going, anybody know what?
Porsche 1984 944 '94 Ford f250 Diesel |
Your clutch slave cylinder is bad, while you are changing things you will want to change the master also.
Brian 1983 Porsche 944 Silver with Brown Interior. 2005 Honda Goldwing 2000 Husaberg 400 2001 Sherco 2.9 1968 Honda CT-90 2001 Arctic Cat 500 Auto 1998 Toyota PU 2001 Toyota Highlander AWD 1991 Tiffin Motorcoach 2006 Suzuki 450 Super Motar |
so i just need to replace my master and slave cyl.? any other parts i should replace? my clutch is only at 25mm approx.
when you say test hole, do you mean the bleeder hole at the back of the cylinder?
if so, put a 7mm wrench on there and try to tighten it up.. it may have just backed out a bit.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
by test hole i mean the place where you can measure the clutch wear
So is there anything else i should replace while replacing the slave and master cyl.?
Joe Chen Current fleet: '93 Amethyst Violet 968 Cab "Lila" (back in the fleet!) ; '92 Cobalt Blue 968 Cab "Minjonet" - Canadian car '88 Silberossa 951S "Rosy" - garage queen ; Secret project ; '99 Ford Ranger ; '00 Kawi ZX6R Former cars: '94 Black 968 Cab "Steffi" (totaled) '87 Nautic Blue 944 S3 "Emma" (blown motor) ; '90 White 944S2 ; parts cars
