18" Wheels from 996 fit S2?
Front: 8 J x 18 ET 52 ; 225/40 ZR 18 tire
Rear: 10 J x 18 ET 65 ; 285/30 ZR 18 tire
Will I need spacers?
Thanks.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-23-2007, 01:02 PM
cold starter
JustinL's Avatar
Grab a tape measure and use this tool: http://www.1010tires.com/WheelOffsetCalculator.asp
You should be able to see if you will have the clearance.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 05-24-2007, 12:03 PM
You sure you want to stuff some 18"s under there? I think I've seen it done before, but it looks like it's at the limit.
-See I need new wheels also
-I really like the styles that only come in 18"
- However I don't want to change/decrease the cars handling in any way.
Old 05-24-2007, 03:46 PM
Thanks Justin.
Based on the calculator, it should fit.
I just don't know if the front bearing grease cup will be a problem.
When I tried my 1993 C2 16-inch wheels on the S2, the grease cover was in the way.
I will probably pass up.
Old 05-24-2007, 04:47 PM
Non Compos Mentis
Unless you tweek the suspension, the car will understeer like a pig with those tire sizes.
285's will fit, but I wouldn't want them on my car.
Old 05-24-2007, 06:59 PM
74goldtarga's Avatar
Pretty sure the wheels will fit, front should be ok especially with a little added camber (need spacers I think - see below). I know the rear wheels will fit but unsure about that tire size - I have seen 18" x 10" with 295 on the rear but not sure if any mods were necessary. Agree with Dantilla on tire size balance.
This is from wheel dynamics web site:
"No spacers needed for newer17"- 18" wheels in the 48 mm-65mm et range. All 986, 996, 997, part# wheels will require a 1/4" (7mm) for the front hub. This is so the wheels will mount flush on the hub. This is needed for all newer wheels. 993 part# wheels will not need the spacer.
Most extreme fitment-Front 18x9 et52mm -Rear 18x11 et65mm
18x8et 50mm and 18x10et 65mm on 1991 944 S2 below"
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 05-24-2007, 08:11 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Based on what I've learned here, you should consider replacing the caster blocks any time you go over a 16" wheel. This was pointed out to me by Techno Duck and AE1969...search for the thread if you are interested.
Edit:
Here is the thread:
http://forums.pelicanparts.com/showthread.php?threadid=326070&highlight=eccentric+bolts
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 05-25-2007, 08:25 AM
I don't have the car anymore. I gave it away to my son.
But he was considering changing the wheels to 18's for street use.
Thanks Tom for the info.
I changed to the 968 rear caster block 2 years ago together with lball joint and CNC machined bronze bushes.
Also changed the tie-rod assemblies on both sides.
So the car is ready for wheel upgrades.
Old 05-25-2007, 10:43 AM
