Removing Torque Tube - Problem with Clamp Sleeve
I'm trying to separate the torque tube and the clamp sleeve will not let go of the driveshaft. I have spun the 8mm allen wrench style bolt completely out but the shaft remains in place. Any suggestions????????
FYI - I have the transaxle and the TT out of the car.
2015 GLK (Momma's ride) 2016 F-250 2001 BMW M5 65 CSX 427 Roadster |
winter-hater club member
bigger hammer!
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
heat and leverage
83 944....bye bye 85.5 euro spec 944, 5sp (she's gone.... ![]() 74 914...hasta LA Vista baby 87 924s....don't let the door hit ya 68 912.......see ya! |
What is the clamp made of? It appears to be plastic.
I think I dinked up by removing the transaxle housing bolts first before I loosened the clamp........Do I need to put the bolts back in or do I put a torch on the clamp???
Burn the fire.
You should have the trans still attached to the torque tube before taking that clamp off. It is made of steel (not plastic).
Spray a little P&B Catalyst on it, let it soak for a few hours while you take a beer break. Through the inspection window you can usually pry the sleeve back towards the transmission side with a bit prybar or flathead screwdriver. Never had one I couldn't get off with patience and maybe a torch at the last straw.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
