HELP - need spark plug wire / dist cap order for 87 944S
Long story but I need some direction on which spark plug wire goes where on the distributor on my 87 944S.
I did a search but no luck - any direction would be appreciated. If you have an 87-88 944S perhaps you could take a look and tell me "wire from front cylinder goes to top of dist, wire from second from front goes to second....etc. Or perhaps you know of a link to diagram??? Thanks! |
Thanks Edek but it does not give the precise order of wire connection. I'll keep looking.....
There is a link on that site that brings up a picture of the distributor cap with numbers. Cylinders are numbered 1 through 4, front to back. This is a piece of cake.
Buskey,
Cylinders are numbered 1 to 4 from front to back. On the distributor cap: 3 (top) 1 2 4 (bottom) The S is different. The distributor cap has all its connections vertically on the side towards the driver. The coil plugs in on the opposite side (passenger). Even if you buy a new cap, I have found the numberings on them incorrect. Darren '87 944S |
I forgot that there were two types of caps.
BTW, welcome Darren. |
Awesome, thanks Darren, and welcome!
Edek, I should have mentioned that the S is different. Thanks for your help as well. Bill |
| All times are GMT -8. The time now is 10:43 AM. |
