HELP - need spark plug wire / dist cap order for 87 944S
Long story but I need some direction on which spark plug wire goes where on the distributor on my 87 944S.
I did a search but no luck - any direction would be appreciated. If you have an 87-88 944S perhaps you could take a look and tell me "wire from front cylinder goes to top of dist, wire from second from front goes to second....etc.
Or perhaps you know of a link to diagram???
Thanks!
Old 06-21-2007, 09:06 PM
Politically Incorrect
onZedge's Avatar
Hope this helps:
http://www.clarks-garage.com/shop-manual/ign-01.htm
Edek
'87 924S
'91 535i
Old 06-21-2007, 09:19 PM
Thanks Edek but it does not give the precise order of wire connection. I'll keep looking.....
Too many projects to list......
Old 06-21-2007, 10:18 PM
onZedge's Avatar
There is a link on that site that brings up a picture of the distributor cap with numbers. Cylinders are numbered 1 through 4, front to back. This is a piece of cake.
Edek
'87 924S
'91 535i
Old 06-21-2007, 10:36 PM
Buskey,
Cylinders are numbered 1 to 4 from front to back.
On the distributor cap:
3 (top)
1
2
4 (bottom)
The S is different. The distributor cap has all its connections
vertically on the side towards the driver. The coil plugs in
on the opposite side (passenger).
Even if you buy a new cap, I have found the numberings on
them incorrect.
Darren
'87 944S
Old 06-21-2007, 10:54 PM
onZedge's Avatar
I forgot that there were two types of caps.
BTW, welcome Darren.
Edek
'87 924S
'91 535i
Old 06-21-2007, 11:12 PM
Awesome, thanks Darren, and welcome!
Edek, I should have mentioned that the S is different. Thanks for your help as well.
Bill
Old 06-22-2007, 05:45 AM
